He won't win any races
but he might feel invincible against any floatsom.
I'm with Ross on the new paints that are available, it should'nt be too much of a problem for maintenance. But, I would think that condensation may be a source of "opportunities" for problems.
As for the cold weather and ice, I seem to remember a documentary about the "Liberty Ships" that brought US GI's over to Europe that literally broke apart. Turns out it was the grade of steel - it became so brittle that it literally cracked in two! So, cold weather durability depends greatly on the type of steel used!
I certainly may question the type of steel and the carbon content!
Other issues that I would worry about is the Craftsmanship involved. Someone recently posted that welders are a dime a dozen - I could not disagree with him more. Welding is an art and a science. The welder can make or break a design. Arc Blow when welding into corners is tricky to hold a good weld. So is overhead welding. Was the construction done in MIG welding or SMAW(Stick) welding. Anyone in the trade will tell you that stick welding with a 6010 rod is a pipefitters bread and butter. A good welder can make that rod dance!
Look for warping of the metal to see if too much heat was applied. Long passes need to be broken up frequently and it is the craftsman who can make a long pass look like a continuous bead that looks like stacked nickels.
If you see any slag remaining or porosity at any joint - I would question the craftsmanship.
