Masts jerk and wiggle!
THE BAD NEWS:I have had the same problem almost exactly.Here's what I've learned so far on my 79 H30:First, check the breaker switch with a mutimeter (Harbor Frieght Tools has them cheap, but they work OK for checking 12v circuit current) if you have 12.0 v +/- current when you attach leads to the pos. and grnd. posts on that breaker for the circuit, go to the first splice/connecting point in the wire set. In my case it's at the overhead, behind a teak facia board in the head,just behind the Mast support. Test current there. If you get a 12.0 v +/- reading, your half way home. If not, check connections at the breaker and/or replace breaker itself, and/or, check the wire from the breaker to the first splice Then check continuity of the wires that go vertical through the over head to the mast head light. If you don't get a reading, you either have a break in the wire from inside the boat to the deck connector fitting (or internal fitting in the mast) or from the connector fitting to the light fixture. Check the deck fitting connector for current (with breaker switch 'on'), then check continuity from the deck plug to the fixture...If the test fails, remember, with the mast banging, wiggleing, bending etc. you may have a broken bulb (Most likely situation) or a broken wire connection to the fixture.THE GOOD NEWS:I found an easy teporary fix myself: A good quality Hikers Headlamp with a Xenon bulb. Since the lens on the headlamp is recessed, look for one of many sizes of bottled water with faceted bottom, cut the bottom 2" off , check fit over the lens/housing, trim as necessary, tape add-on 'lens' on with clear duct tape (Lowes). Then loosen head strap and re-attach to mast as high as you can reach. If you are steaming for more than six hours, simply unstrap, exchange batts, and re-mount.It actually meets USCG regs. and is brighter than OEM installed steaming lights of the past. Hope this helps... George
