Steaming Light Replacement Bulb - Forespar?
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Greetings,
I have a combination steaming and foredeck light. I think it may be a Forespar, but I'm not sure. I have no record of it, and only a crude pic:
The steaming light is out. I'd like to purchase an LED bulb for it to hand to the guy at the boatyard who's to go up and replace it.
Does anyone recognize this light? Know the bulb?
p.s. I had zero luck searching for Forespar, etc.
Thanks,
jv
jviss
Feb 5, 2004
7,089
Visit
I replaced the deck light bulb. The bulb you are looking for is listed on the last photo, part number 8GA 003 488-301 12V, you need the LED replacement.
Visit HELLA MARINE 8GA 003 488-301 | Bulb 25 WATTS 12 VOLTS $ 15.98
for the original bulb.
Ah, thank you. So you figure it's the Hella combination light? I pulled on that thread and found the masthead, i.e., steaming light for that fixture is a festoon bulb, SV 8.5. So, I'd need the LED version of that.
Thanks,
jv
jviss
Feb 5, 2004
7,089
Thanks,
jv
It looks like it's a 31mm festoon bulb, the "premium" version is $29 at West Marine, in stock.
jviss
Feb 5, 2004
7,089
Whoops, maybe not a navigation light bulb...the search continues.
jviss
Feb 5, 2004
7,089
Found Dr. LED replacement at Defender. Now, what else do I need from Defender? I always remember after I've place my order!
Jun 21, 2004
2,907
Beneteau 343 Slidell, LA
Guess it depends on how much you motor or motor sail at night & the life expectancy of LED vs incandescent for your usage. I recently replaced the deck light in the combo deck steaming light: however, I opted to allow the incandescent light to remain, as batteries are being charged while under power.
jviss
Feb 5, 2004
7,089
Yes, I get that. Incandescent were $1.88, LED $28.99! But, considering the cost of having someone at the boat yard swap it, it's cheap.
