L
larry stanton
Help!!! I have been fighting a steaming light problem for some time. I do not have any wiring details indicating how the mast light is wired to the system. I have attempted to pull the old wiring out, but it appears to be plugged into or otherwise connected to the source under the maststep ( no real access). Would a wire fish work?The porblems are: The light was not switched (it went on and off at will!). It was wired straight to the battery. No doubt a short in the mast. It first went on then off again when we delivered the boat. I came back to the boat after a week and found it on. Odd!! I have installed a battery shut off switch to prevent that problem. Now it will not operated at all. I am sure that the wiring is damaged inside the mast and wish to replace all of it. I have replaced the old curcuit panel and cleaned up the wiring mess as well.I would really appreceate any and all assistance. Lots of trips up the mast and nothing but sore legs and dropped stuff to show for it!!!Larry StantonIrish RoseOday 27
