John
1983 catalina 30 tall rig-I have no juice at the steaming light. I have been up there twice with a voltmeter and bulbs. I have juice at the panel switch. Changed fuse, still nothing. Anchor light works!? I may have to give up until next winter when the mast is unstepped. Last winter I changed the connection "trailer plug" on the deck and everything tested fine. Maybe the wire was damaged when the mast was stepped? I don't see how the wire goes between the panel switch to the compression post. I thought it would exit the compression post in the bilge, but there is no sign of it.
