I recently (8 months ago )did a complete upper on my Catalina 30 with an M25. Its ran great until recently when it started blowing steam out of the exhaust. It only does it when the Radiator cap is on and it starts in about 30 seconds when I put the cap on. I put a pressure gauge to test and it help pressure but as soon as the motor starts there is immediate pressure on the cap..I changed the water pump both, cap, thermostat and upgraded from 2 to 3in heat exchanger. The rad fluid is not leaking as the level stays where it is supposed to so I am assuming the fresh water is somehow turning to steam ..do you think its the head gasket or is there somewhere else this can happen...
