HDT
The HEAT DEFLECTION TEMPERATURE is the temperature at which the strength of a material begins to degrade as determined by ASTM D-2583. (Sometimes referred to as Heat Distortion Point).Resins can benefit by increasing in strength from the post-curing process that occurs under increased heat, up to a point. That point is the Heat Deflection Temperature (HDT) and varies for different resins. As Polyester approaches its heat deflection temperature (HDT) which varies wildly between formulations (commonly 90 Deg. - 130 Deg C - some exotic industrial applications up to 300 Deg C) in case of isophthalic acid based polyester, their rigid structure becomes amorphous & flexible and they transform to a rubbery state and this deformation progresses more & more near its HDT.I did not (earlier) get more specific about Steam damage to Gelcoat, due to this tremendous variation in HDT’s, between differing Polyester formulations. Not knowing what product your boat has, and not having all the various product spec’s, I couldn’t offer a definite maximum temperature, nor a degradation curve as you approach that temperature.Suffice it to say - the gelcoat will weaken as it heats up (many manufacturers won't warrantee their products id Dark colored in the Tropics), and ultimately Fail @ some point - probably below 100 Deg C (Steam).I’m glad you decided against steaming the boat - it wouldn’t be advisable - no matter what product you’ve got.
