Staying to the Right -- What Constitutes a Narrow Channel?
  • Thread starter rardi : H36 ( Cherubini)
  • Start date
Having read and taken on board many of the Rules of the Road concepts (at least the most important ones) since I started boating again last year, I wonder if I've misinterpreted something either with the rules; or with common boaters' etiquette.
Very frequently, other boats proceeding up or down the local channel are either right in the middle of it or on the left side (i.e. hugging the red day markers when heading out or on the other side when returning). I’m referring here to cruising sailboats which are by far the majority boat class in the area. I’m generally not as concerned about the movements of small powerboats, or jet skis, or anchor-out people moving about in their small boats.
For instance, today I was returning to my marina and staying to well to the right side of the channel with the red day markers on my right. Several hundred yards ahead I noticed that another boat (mid sized cruising sailboat) was coming out the channel on my side. The operator was really hugging the edge of the channel, so we probably would have passed starboard-to-starboard with a few dozen feet clearance. But the boat was moving with steadfast purpose and was giving no indication being aware of my presense. Both of us had sails down and we were under motor power. Well before any danger situation developed, I made a pronounced deviation to left side of the channel and then a pronounced return to my original heading when well out of the way of any possible collision. So now I'm proceeding along on the left side of the channel. Passing starboard-to-starboard 30 to 60 seconds later, the folks in the other boat (50's-60's types like me ... not young but not old either), gave not so much as a nod of recognition that I had moved out of their (wrong side of the channel?) way. I don’t think they were being intentionally rude. Just that this was their normal way of leaving the harbor.
My version of "Chapman Piloting" says: "A vessel in a narrow channel must keep to the right and as close to the outer limit of the channel as is safe and practical. This rule places a burden on a vessel on the left side to (1) be there only if she must and (2) establish an agreement for a starboard-to-starboard passage.
The boat today met neither condition.
The local channel isn't critically narrow, but it’s not a six-lane freeway either. Current in the channel generally is insignificant as far as influence on boat handling is concerned. The right side of the channel (inbound) is well defined by red day markers. The other side is just the shore side along which there are the entrances to the dozen or so marinas in town.
I really don't get upset about boats going in or out on the left or right up the middle of the channel. Its less mentally stressful instead to pay attention and to take action so that I’m well out of anybody’s way. This is also easier and safer to my mind’s eye than scrambling for the air horn to give the appropriate sound signal and then wondering if the other guy has heard it or will interpret it correctly.
Am I missing something about Rules of the Road ... or should I recognize that it’s "a game of chicken" out there?
C
Captain Chuck
good question
Rule 9 sets forth the actions required in a "narrow channel" as you found in Chapmans. It does not however define "narrow channel". As the operator of your vessel you are required to take action to avoid a collision. Action must be positive and taken in ample time as to be readily apparent to the other vessel (Rule 8). Keep in mind the regulations do not refer to "right of way". Rule 14 sets forth the actions required in a head on situation. Basically what you encountered. The rule requires both vessels to alter course, therefore becomming the give way vessel, to starboard. Since the other vessel was not acting according to this rule you were required to take appropriate action to avoid a collision under Rule 8.
Brian D
Hmmm...
Do you have an air horn? Did you use it?
Normally I stay on the windward side of the channel if I am the only boat. Keeps me from drifting out of the channel if a strong wind is abeam. However, the other boat "should" have been on his right side of the channel. Hence the air horn. One long blast to get his attention. You did right to avoid a collision, but I still think the other boat was in the wrong.
To me, a narrow channel is one that will bring vessels too close when passing and could result in damage to either vessel if one deviates from their course.
Bay Sailor
The other boat made it a narrow channel
I would have given that boat one blast of my air horn and turned to starboard before he got close. That should have signaled my intention to pass him on my port side. Turning to port is the last thing the captain of the SS Andrea Doria did.
TimCup
Rardi-
Is it possible they had a deep keel? It doesn't make it right, but if they had experienced any kind of grounding further in to shore, they may be taking the absolute safest path, as there were no markers showing the other side of the channel.
Based on your description, it sounds as though they were "looking out for #1", the rest of the world be damned. If they can't acknowledge you with a wave, I doubt they're concerned about etiquette (and by that I mean they will force you to make the avoiding move- since there was no danger, thanks to your actions, they had no requirement to change heading).
Sometimes 'chicken' is played by bullies.
cup
