My boat came with this charger permanently installed. I thought that I would try it out.
1) battery voltage was approximately 12vdc, I connected the AC voltage. The charger seemed to go through a power up cycle and then the "ready-float" and the "bulk" LEDs started flashing simultaneously.
According to the manual this is indicative of the battery voltage being too high, possibly connected to another charging source. It was connected to my outboard motor but the motor was not running
2) the next day I dismounted the charger, checked all the wiring ( it seems to be ok) checked the gell/flooded switch ( it was in the flooded position which shoulder ok since my battery is a normal wet cell marine battery). I checked the output fuses. One fuse was blown. Since I didn't have spare fuse I moved the other fuse over. I suspect that these are on the output lines to two separate battery outputs (I only have one battery in the boat).
Now, without the AC connected the "bulk" LED is flashing. According to the manual this means that the charger has shutdown due to overheating. (Definitely wasn't too warm in the boat)
I did not have AC available so could not try that out.
According to the manual, if a fuse is blown the charger would be "continuously resetting". I've never seen it do this.
Next steps....
1) buy and install replacement fuse
2) retry and then connect to AC
I'm hoping the charger is functional. According to PO it was fairly recently installed.
Any further advice would be welcome.
Next steps....
