First, after switching power on to motor at control pannel is there a separate switch for fuel pump and should I hear it clicking away like old british sports car? Second, is throttle and gear shift combined in lever/pull knob control I believe so but don't know how it is suppose to work? Maual does not show it. Third, does battery master have to be on (take it easy) my motor is wired directly to battery and battery selector has loose cable coming from it. Not sure if cable is plus or neg. but could not find fuse pannel so I am tracing out house 12volt system ...could use some tips here too....cheers frank
