Derek Rowell
I'll try to make a long story short...When we purchased Destiny last year we had starting problems, and I had to bleed the engine (Yanmar 4JH-TE) whenever she sat for more than 3-4 days. I searched in vain for air leaks around the fuel system. Earlier this year I had the yard look into it, and they found that there was a leak in the small (about 1/8" diam.) rubber cap on the end of the fuel return line, at the last injector in the chain. Made sense, that would let air into the system. They didn't have the Yanmar part so they put a temporary cap on, with the promise to install the proper part as soon as it came in. Everything worked great, the engine would start immediately, until about a month ago, when the same starting problems started again. The yard said that they had put the Yanmar cap on.Yesterday I decided it was time to get to the bottom of the problem again. The engine would not start, despite bleeding it twice. When I went down to the engine room after cranking, I could hear a whistling sound, like air being sucked in somewhere around the injectors. As soon as I touched the new rubber cap on the return line it broke and fell right off! It was as if it was rotten, and it crumbled between my fingers. That was obviously the problem. So my question is: what destroyed that rubber cap in less than four months? Are there some rubber-like materials that are "eaten" by diesel? And the bigger question for me is - did the yard in fact use the proper Yanmar part? I'll be on their doorstep at 8am tomorrrow!)Derek
