Jack
I posted a couple of weeks ago about having starting issue. The starter engages but 'sometimes' cranks slow as if the batteries were near death. I got a lot of good advice and checked out all points of view that were posted for me. The best advice, dare I say, was to "Do it yourselve" and not waste money hiring fools. Anyway, the next thing i would like to try is replacing the starter button and the wire that runs from the starter button to the solenoid. I would also replace the 30 amp inline fuse. I have read in the past the adding a car horn relay also helps boost amps or volts. My question is why does this help and where do I install the relay? How is it connected. I should have started with some background but the engine is the m-18 diesel with a new starter, alternator, newer batteries and everything has been tested a dozen times. thanks, jack
