Starting Battery Location
3
Catalina 310 Sackets Harbor, Lake Ontario
For those who have added a starting battery, where did you put it? Does it fit in with the two existing batteries? Also, any comments on battery combiners (i.e. relays)? Jeff Merrill
Jon W.
May 18, 2004
401
Catalina 310 C310 Seattle Wa
I like the small size of that battery
Does someone know what battery that is pictured?
Feb 6, 1998
11,763
It's a group 27
Starting battery by made by Johnson Controls under the Douglass brand but all group 27's are the same case size. A starting battery is often used as an emergency back up battery and 99% of the time is not used. We always start with our house bank.
There is little need for a combiner if you keep your boat at a dock plugged in because the 310 is set up to charge both banks while on shore power. Decide which bank you need to charge, usually the house bank, and keep the switch set there. By not using your start battery for house loads it is always ready. Our house bank is position 1 and 99% of the time that's my selector position and the alternator charges the house bank only and gets automatically combined with a Yandina Combiner.
Feb 6, 1998
11,763
Don't go 8D!
Quote: "I had discussed with him the option of adding a starter battery on one circuit and putting the two stock 4D's in parallel for the house battery. He asked his instructor for his opinion and the instructor suggested buying a single new 8D and using one of the 4D's as a starter. The 4D's are being used now. I would have to look at the 8D's to compare AmpHours and reserve, etc. It merits some further discussion."
One 8D battery (Exide Marine Deep Cycle) weighs roughly 134 pounds and delivers only 200 amp hours while two 4D's weigh 196 pounds combined yet deliver 320 amp hours. 130 amp hours is a lot more punch than 200ah and besides you already have the 4D's. I personally don't like 12V batteries and much prefer 6V batteries in series/parallel to create a 12V bank. This is only if they will fit as 6V batts are generally taller than typical 12V batteries.
The ONLY reason we have the 4D's on our boat is because they were brand new and came with the boat, and I could not justify throwing them away. When they reach the end of their useful life I'd replace them with 4 Trojan T105 6V golf cart batteries. Four T105's weigh only about 204 pounds yet yield an amazing 450 amp hours. Compare that to an Exide Gold Marine Deep cycle 8D at 200 amp hours and 134 pounds a lot more punch for not a ton more weight. Plus a human being can actually handle a single 50 pound battery yet a single 134 pounder is nearly impossible to carry out of a boat each winter!
Trust me those 4D's are a bear compared to four individual 6V's. and they are 35 pounds less than an 8D. You're getting more than double the out put for very little extra weight with 6V. Plus the 6V batteries will last a lot longer. Thicker plates mean longer life. My brother has a bank of Sam's Club 6V golf cart batteries in his boat going on 6 years now and he paid less than $200.00, at the time, for four of them! Keep the 4D's until they need to be replace then consider your replacement options with either two 6V(225ah) or four 6V (450ah).
Nov 27, 2005
163
- - West Des Moines, Iowa
John W if you are talking about the battery pic
in Chris Conners post I am pretty sure they are a bank of 4D batteries. Also to Maine Sails points about weight. For deep cycle batteries Weight of the battery has a loose corallation to A/H's. Most 4D batteries I know are close to 110 lbs, although those are closer to 200 A/H's. I would think that if you are only getting 160 A/H's then under 100 lbs make sense.
Jon W.
May 18, 2004
401
No, the small battery.
It looks to me like there is a small battery to the left of the 4D's in that picture. I've been keeping my eyes open for a real small one, because I don't seem to have as much room in my battery compartment as some of the pictures seem to show. The batteries on my boat 2000' boat are turned 90 degrees from some of the later boats I've seen, and there isn't much room between the batteries and the point where the hull turns up. Zero room on the inside or the fore or aft side.
Jon W.
May 18, 2004
401
Chris
Interesting comparison photos. It looks like they cut out some of the fiberglass to put your batteries in 90 degrees from mine. I guess the compartment is the same size. Mine just looks fuller to me. If Maine Sail answers this thread, he might tell me what that small battery he used is.
Jon W.
May 18, 2004
401
Sorry I missed that.
Thanks. I didn't see your previous post.
