starting batteries charged but no power to panel
Swaney
Jul 27, 2020
16
oday oday 34 Chareleston
My panel has no power but charging batteries are charged and starter has no juice bilge pun also no power. I have not had this problem before so I look to the board for assistance.
Dec 14, 2003
1,446
Check & clean your battery terminals. No power to panel, and none to the bilge. Since bilge pump is normally wired directly on the battery, I would probably suspect problem with the negative side. Not a bad idea to clean both sides anyway.
Jan 4, 2006
7,441
Using the least to most investigation procedure, try rotating your battery selector switch a few times to ensure it's making contact.
Sep 4, 2007
782
Hunter 33.5 Elbow, Saskatchwen, Can.
Possible ground wire issue. I would check all the grounds, batteries, engine, etc.
