Greetings All,
I have an '84 Cat with the 23HP three cyl diesel, and have been having some issues with the starter. The engine started very strong for the past two months, and now i can barely get the thing to turn over. It still turns, just incredibly slowly, and nowhere near strong enough to get the engine to fire. I originally started at the batteries, thinking they surely must be drained, but when i checked them against my volt meter, they were a strong 13.45 volts, hooked in parallel, and producing almost identical charge when i disconnected them from each other. After checking the 12 volts, i decided to follow up with my 6 volt house bank. These were also producing roughly 6.8 volts, so all batteries are perfectly healthy, and it must be something else. I checked the transmission next to make sure i wasn't spinning the shaft while trying to start the engine, fortunately i wasn't, but now i find myself truly puzzled as to what the issue could be. I'm afraid that it could be an electrical short, but thought that if a short did exist, then the starter would just not react at all. I would prefer not to have to take out the starter for a rebuild, but it looks like i'm running out of options. Please let me know if anyone has any advice or recommendations, i really appreciate your input. Y'all have a nice day.
