Steve
I want to replace my copression block under the mast in the bilge with starboard. I spoke with the company that makes the product and they say that it will work fine for that application. The engineer I spoke with said that some boat manufactures are using there material for this process. The engineer said that it dosen't absorb water and the compression strength is greater than wood. He told me to cut the pieces and stack them to the desired highth and put a couple of stainless screws to hold them together. I'm planning on doing this with the mast up with the stays and shrouds loose. I will try to lift the floor with some screw jacks made with 5/8 rod and some steel plates. Please let me know if you think this system will work. Thanks in advance for you advice!
