Stantion Base Bolt Attachment
droehl
Nov 22, 2010
1
Beneteau 325 Grosse Pointe
Would anybody know how the stantion base bolts are secured on on Hunter 386 (or similar)? Are the bolts threaded into the fiberglass or is there a nut or some type of threaded nut plate? Access on the under side is covered by the ceiling panel.
Thank you
I don't know about the 386 but on the H26 there is a threaded plate glassed in. I assume it is SS but it might be aluminum.
JamesG161
Feb 14, 2014
8,088
Hunter 430 Waveland, MS
Same on my 1998 H430.
I assume it is Stainless since the bolts and nut are SS too. Hunter quality has shown me that they match metals.
Jim...
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Hunter did use aluminum plates, see the attached PDF regarding Hunter construction in the late 1990s. I have had this interview transcript a long time and can't remember where on the internet I found it, sorry.
Likes: JamesG161
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Our 1989 Hunter 30 has aluminum plates inside the glass. I haven't removed the stantions but everything else on the boat seems to be done this way. It does lead to seized fasteners. I use an impact driver to loosen them and always use anti-seize when reinstalling after chasing the threads with a tap. No problems with this approach yet.
Ken
-na -NA Anywhere USA
As a full Lin former Hunter dealer, if there are no known or seen inspection/access ports seen in the cabin, then the bolts are attached to embedded aluminum plates within the layers of fiberglass that were drilled and tapped first.
Under all hunters look for the e rethread Treasure Trove of information and tap onto the website and look to see what was found by Eddie before he retired from Hunter as warranty mgr. and my dear friend/ customer Jim Seamans and maybe thebdiagram for those embedded plates are there
