J. Barrett
Since January is almost over I figure it is time to look at the tasks needing to be accomplished before the spring launch. A couple of years ago I was motoring back to my slip when the bolt securing the spreaders on my 25 came loose. I was out by myself and initially at a loss as to what to do as the mast rocked side to side with the waves. Fearing that I may loose the mast or at least cause damage I didn't wait too long to act. First, I headed directly into the waves. That stopped the boat from rocking so much and slowed the movement of the mast. Second, I grabbed a line from the cabin and secured it on the upper shroud above the wayward spreader. I ran the line across the boat to the starboard rail and secured it to the base of the stantion. With tension on the shroud the mast was stabilized. In retrospect I would run the line around the base of the stantion and back to the winch since I lost some of the tension on the line while tying it off. Once back at the slip I used a step ladder secured to the mast to climb up and refit the spreader. I made sure to use a nylon locknut when doing so. I had thought that the spreader was secured with a locknut but can't be certain as the nut/washer/whatever went overboard when it came loose. My point is, be sure to check your rigging closely for any loose or worn fittings/connections. If I had been under sail when the spreader came loose there may have been some damage done to the boat, I may have lost the mast, or may have been injured or worse. I saw on a link once where a boat (the Wildhair, I think) lost the mast when the forestay turnbuckle backed out. Mine has cotter pins to prevent this. Has anyone ever drilled and pinned the spreader bolt or any other fittings as a precaution? Any reasons why it would be a bad idea? -John
