Standing Rigging Cost
Martin Hignett
Does anybody know the approximate cost of re-rigging a 37.5 in the US..Thanks...
Martin Hignett
Martin Hignett
Martin Hignett
Dec 2, 1999
15,184
$1100-1200 + installation
Martin: I received a quote from Seco South. They quoted about $1100-1200 about 2 years ago. This was just the materials. I think you need a rigger to swedge the deck ends onto the cables.
Dec 2, 1999
15,184
Dec 2, 1999
15,184
Dec 2, 1999
15,184
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
That sounds...
...a little steep. I paid about $125 per stay for my boat although it was a couple of years ago. I installed them myself. It's really not that hard to do. Next time I'm using the new braided synthetic line for all but the headstay. It's soo much lighter and stronger and there is no creep and you don't need turnbuckles. The cost is only slightly higher than steel cable but the performance increase will be dramatic because of the weight aloft savings. "...A value leading alternative can be braided synthetic line. There are a few good choices here, Vectran and Dynex Dux are 2. A simple understanding of the material and constructional properties is all you need. The price of braided synthetic standing rigging is similar and sometimes even cheaper than steel rigging due to the elimination of hardware like turnbuckles!"
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
That sounds...
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
That sounds...
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
That sounds...
Rick D
Jun 14, 2008
7,188
Adjustments, Alan?
W/O turnbuckles, what would you use to fine-tune the rigging? Is there some type of screw adjustment? RD
Rick D
Jun 14, 2008
7,188
Adjustments, Alan?
C
Capt'n Bob
Tension in the lines
To Alan and others, If you go to braided synethic side stays how would you adjust the tension in the stays ?? At present I use stainless steel side stays and use the P-3 Loos Gauge to set the tension. Plus, how would you terminate the stay at the spreader bar and at the deck ?? Would you set the tension with a turn buckle or is there another way to do it ?? RD
C
Capt'n Bob
