Some Considerations
I beleive the radio you are referring to is indeed of 1970s vintage and manuals will be tough to come by. One clue as to it's present servicibility is the number of channels. If it has a limited number and a rotary knob with perhaps 20 or fewer channels, it is a crystal based radio. At that age, the frequencies are probably out of calibration and your best bet is a new radio. If it has lots of channels, it has synthesized frequency tuning which is not subject to the same aging problems as crystals and may provide you with several more years of service. But generally, given the age of the radio and the fact that it is a pimary piece of safety gear, perhaps consider replacing it with a new one. You generally don't need all the bells and whistles contained in the higher end radios, so you should be able to find a basic VHF in the $100 range.
