Hitting the nail on the head
Hello Charlie. Indeed, this is the stanchion base on the toe rail. No bedding compound in the base itself. Corrosion seems to be the culprit preventing me from accessing the thru-the-hull bolt/nut. Last night a stainless specialist told me that the best way to loosen w/o twisting the cap-hex-head off (or stripping it) is to apply heat quickly and carefully to the cast aluminum. I plan on trying that this weekend.Meanwhile, access beneath the toe rail is complicated by cabinets and such (as if I need to tell you). I recently bought the boat and have replaced every system aboard, engine, reefer, ACwiring, lighting, plumbing, rigging, heating, etc... I was saving the stanchions for last, hoping that the ripping and tearing was pretty much over. But hey... she's a boat, and I love her. Thank you for the reply, John
