Brad Kramer
We just took down the stanchions on our 1986 28.5 Hunter and found that four of the six stanchions had been damaged. They are the same stanchions originally designed for the boat (the stanchion is held by four bolts - one in the base of the stanchion, two in the attached plate to the toe rail and one in the support.) Several of the stanchions supports were bent, two supports were completely separated from the stanchion, and two of the toe rail plates had separated. Needless to say, we were quite surprised and glad that we took the time to examine the stanchions.The question is, what type of new stachion is the best fit (and is stronger)? Does it make any sense to try and repair the stanchions? I am especially perplexed because most of the newer stanchions are supported by brackets that need to be bolted from underneath the deck - the Hunter 28.5 ceiling/wall is a single piece and it doesn't appear that we could attach bolts from below.Any help would be greatly appreciated.Brad
