Don't forget about the weep holes
I am completely repainting my top deck and am about to reinstall the stachion bases. When I removed them, I noticed that there was a channel machined in the underside that ran athwarship. I didn't notice them before I took them off becasue the previous owner had covered them up with silicone.The purpose of the weep hole is to let any condensation/rain/spray on the inside of the stanchion drain out. There were a number of bases that had water in them when I removed them. Luckily, there was little damage from the standing water. So, when you rebed your bases, make sure you don't plug up those weep holes (i.e., just don't smear the sealant on - be judicious in where you place it). One technique I was contemplating was to place some thick yarn (or other suitable material) in the grove then pull it out after I attach the base. The idea is this. The yarn would prevent any sealant from intruding on the grove and if any did, pulling out the yarn before the sealant set would "clean out" the grove.Happy SailingAndyChrysler 22
