Stanchion removal
Albert
Jun 4, 2013
3
Beneteau 85 First 38 ME
I am looking for some advise on removing stanchion posts that are stuck, annozied and sealed into the stanchion bases. I cant seem to loosen the hex bolt or remove the base screws on my 1985 40 Beneteau First 38.5
Albert
Jun 4, 2013
3
Stanchion poles stuck!
Thanks for the reply . I was able to download attachment but it is not the same on an 85. The issue is the stanchion poles bolts are stuck. Possibly b/c they are stainless and base rail is aluminum. Annozation and salt buildup. I was thinking an impact wrench and some liquid wrench might do the trick to loosen the nut. I was able to remove one nut but the pole would then not budge. It could have some sealant holding it in.
I need to remove all poles and pulpit for haul out and trailer transport to a yard for refit. The height is 13.6 feet and thats too high to clear some power lines and bridges on the roads in Maine.
