Stanchion mounts on H410
Oct 27, 2015
3
Hunter H410 Stuart, FL
I am looking for information on how the stanchion bases are mounted on the H410. Are they thru-bolted or just screwed into the bulwarks? I have a few that need to be re-bed and are leaking and wondering how involved this will be as far as accessing the underside if they are thru-bolted.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Screwed in as I remember.
Asking about 410 but your bio indicates 30T. I went from a 30T on a lake to a 410 for coastal cruising.
Sep 12, 2015
94
2002 Hunter 356 Oakville
My 356 has aluminum blocks glassed to the underside of the deck and the stanchions bases screw into the aluminum, I would suggest the construction would be very similar if not the same.
