Stanchion legs...again
Oct 9, 2012
47
Hunter 260 Wing keel Davis, CA
I bought last year a '98 H 260. Soon I noticed the screws of one of the stanchions' legs were loose. This was the port stanchion next to the winch by the companionway. Got useful input from Dave in this forum. Sadly, the aluminum plates embedded in the deck onto which these screws are normally fastened were destroyed. Had to redrill through deck, epoxy, drill again and pass a bolt through for each leg that I fastened with lock nut and large steel washer from the inside. Yes, had to make an opening in the liner to be able to tighten the nut; covered hole (this was the ceiling of the head). Last weekend I notice the same this time in one of the legs of the starboard stanchion. This may be due to previous owner pulling himself up by grabbing the stanchions while climbing on the boat; the repeated jerking may have loosened the screws holding the two legs onto the deck, which had been replaced crudely with large wood screws thus completing the destruction of the embedded plates.
Has something similar happened to anybody else? How did you fix it? Are the aluminum plates embedded in the deck onto which many other fixtures are fastened on, including the forestay tang, likely to be flimsy? Comments will be appreciated.
Albert
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Same on my 95 23.5.I was able to retap to a bigger size bolt.
-na -NA Anywhere USA
The aluminum plates are encapsulated in the fiberglass. Generally, rethreading first and if that did not work, then go to the next size bolt and drill and tap for that. You will probably have to drill the stanchion base as well and do not forget to caulk. If all else fails, then drill thru the deck and headliner and secure as described with large washer and nylon nut and maybe a second nut to insure it will never loosen up.
Now for the hole in the ceiling. No sweat. On some of the older Hunters, to acess nuts, Hunter generally put a plastic cap to cover that up and the only colors are white, black and beige which come in several sizes. Not sure if this store site has them but a good hardware store will have them and I think Lowes, etc. might carry them too.
Make sure you always caulk and caulk liberally. Use of alcohol would be suggested as some ceilings liners are plastic based and acetone will melt plastics. Hope this helps.
