stanchion bolt pulled thru deck
rod teen
I have a question on how to re insert a stanchion bolt to the deck of my hunter 30. Someone pulled on the top of the stanchion and pull the bolts out from the deck. Not sure how they are attached. can someone help.
Dec 2, 1999
15,184
Suppose to be thru bolted.
Rod: They are suppose to be thru bolted. They have "LIFELINES" attached to them. There should be bolts that go all the way thru the deck and it should have a backing plate or fender washers with nuts on the bolts. Now if you had screws in your it could be because someone removed them and thought that was the easy way reattach. Assuming that you can get to the backing plate. I would drill out the holes larger than the bolts (one and a half or two times the size of the bolts) that are going to be used. Fill the holes with epoxy. This will prevent water from getting into the deck core. Once the epoxy is cured, you can redill the holes and caulk with a good caulking (not silicone or 5200) or use buytl tape.
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Stanchion-base fix.
If it has really ripped through the flange and deck (inconceivable and inexcusable as that is) there is only one way to deal with this. Make your own backing plate out of fibreglass. Go underneath and find out how big of a flat plate you can have that will accommodate all the stanchion's holes and extend 3-4 inches all around (or as far as possible). It's got to be significantly bigger than the stainless-steel backing plate. Lay this up using woven roving or Fabmat on a flat piece of plywood with shiny Formica on it, well waxed with mould-release agent. Make it bigger than it has to be and trim it to fit when it's cured. Go inside again and dewax and scuff up the underside of the flange (low-speed grinder with 36-60 grit or mild wire wheel OK). Wet out the new part, the underside of the flange, and one piece of plain mat for between them. Prop the plate into position (so it doesn't fall; so it doesn't allow voids between the two surfaces). Wait for a full cure. Drill down through the old holes and through the new part. Use longer SS bolts than before and reinstall the stanchion with the proper SS backing plate. (If there isn't one, then that was your problem.) Bed the base down to the deck with 5200. Use aircraft locknuts and torque till there is little wiggle (it's not the 5200's job to give it strength so cure time will NOT improve rigidity). The stanchion when wiggled from the top should flex the deck a VERY little. Let the 5200 ooze about 1/4-inch all round. Wipe it with a rag damp (not 'wet') with gasoline about 1-2 hours later. This one stanchion will now probably be the strongest one on the boat!!! BTW-- this 'fix' is typical for any pulled-through-deck hassle. Remember using the same material as the deck (fibreglass) is key to adding strength. Simply using a SS backing plate, even an oversized one, will not provide the same rigidity and strength per ounce of weight than this. Also, you can do it yourself and later gloat that your handiwork is better than the factory's was! JC
