sand sailor,
Not sure where you are going with this. Of course bolts are available in many different types. But “grade 8” stainless bolts can’t be made from either 304 or 316 types of stainless and type A325 bolts are steel not stainless steel. If you want “grade 8” stainless bolts you need to use something like 17-4PH stainless. This is a type of stainless that can be hardened where 304 and 316 bolts cannot be hardened and they are what they are and can’t be more then that. Type 304 is stronger then type 316 bolts as far as I know and if you know of a suppler that has something else I would be very interested.All the best,Robert Gainer
