Rusting away again in ....
Dec.5, 2000Dear Anthony,You've gotten some good advice from the other posts sent in response to your querry. For further information on galvanic action, any well written modern boat building text covers the topic, especially in the steel and aluminum boat building field. Check them out of your local library.Your going to have to dismount the hardware and isolate it mechanically from the mast. That means remounting it on a non - conductive base plate and isolating the fasteners using one of the insulating creams that have been recommended. Don't delay getting this done because the cost of repair or replacement can be horrendous if the galvanic process gets too far advanced. Structural damage to the mast can occur which can lead to the mast collapsing.Good luck with the project , and while your at it may I refer you to J. Cherubini's post on dealing with inanimate objects?Brian Pickton@BeneteauOwners.netAboard The Legend, Rodney Bay, St. Lucia
