Stainless cleaner
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
What product is brush on to clean stainless and rinse with garden hose what is it called.
Nick
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
Spotless Stainless. Also CitriSurf 2310 Gel. I have used both with essentially equal results. Both work best with surface temps above 75 degrees. The CitriSurf 2310 Gel is avaialble from The Rust Store. It is much less expensive than Spotless Stainless but it is available in gallons.
Likes: Bob S
CYQK
Sep 11, 2009
595
beneteau first 42 kenora
Nick
Rich is correct spotless stainless works great for normal use. If your stainless needs a major rescue go to a welding supply store and ask for Blue One Pickling Paste 130. Be careful with the stuff it is very "effective" you can experiment by diluting it to achieve best results
Dec 19, 2006
5,832
Thanks guys couldn’t remember as info for some one asking me what I hadused
Jul 5, 2011
754
Oday 28 Madison, CT
P21S (or S100 brand also) Polishing Soap works very well. German-made and similar to what their silversmiths use. Water-based soap cake for either rinse off or let dry and buff out. Works on many other surfaces like powder coated deck furniture, bathroom fixtures, glass, etc. Amazon sells. Under $20 and goes a long way.
Mar 26, 2011
3,841
Corsair F-24 MK I Deale, MD
Also Cit
Also generaic citric acid (the above are gelled citric acid) if you can soak it. Citric acid without gelling doesnt have enough dwell time.
