Stain color for the Interior
wojo59
Apr 3, 2009
15
Hunter 34 SkipJack Cove Resort
Hi all,
I own a 1983 hunter 34. I am in the process of re-doing the interior. Does anyone know what is the color of the stain used for the interior?
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
If it is as original it isn't stain ,it is teak veneer finished with Dalys Seafin. Easy to put on
G
gregw
Daley's Seafin Teak Oil
When I purchased my used 1983 31, I called Hunter and they indicated indeed it was Daley's Seafin Teak Oil. I spread it on my own interior using a form brush and then wiped it off after 30 seconds or so. It worked out very nice.
Greg W.
SlipAway
wojo59
Apr 3, 2009
15
thank you.. I need to re-place most of the ply-wood on the sides of the benches. Not sure yet of what to use....
Oct 14, 2005
2,191
Wojo...
you could use Birch cabinet plywood and a Min-Wax stain to get close to the original finish color of the interior. Instead of the Daley's a PO of my H34 used a satin finish varnish. I've found that this makes cleaning a lot easier with the pores of the wood sealed. It has made the interior wood somewhat darker however, coming close to a red mahogany patina now.
