Stability
11,386
If McGregor didn't calculate them at design time (which I really doubt) you are on your own. Happily there are some standard formulas that will get you started. Good thing you wanted to leave out the water ballast, it usually messes this up.
http://www.sailingusa.info/cal__avs.htm
Jul 29, 2010
1,392
Macgregor 76 V-25 #928 Lake Mead, Nevada
Venture 22's are self righting. Voice of experience. Got knocked down. Released main halyard and boat righted itself. Not an engineer so don't know about righting moment. Fair winds and full sails....
Nov 8, 2010
11,386
Every boat can capsize. The Center of Gravity (CG) gets over the Center of Buoyancy (CB) and over she goes. This is the so-called Point (or Angle) of Vanishing Stability. Once it gets to this point, she will usually continue to fully invert, and the boat is normally pretty happy being upside down. Self-righting is simply a term used to describe boats with very high AVS numbers. Above 145 will usually do it, but ideally you look at the whole GZ curve. The smaller the part under the line, the less likely to capsize, and the more likely she will self-right.
As Mitiempo points out, this full calculation is very complex. Done correctly, it takes into account the shape of the keel to calculate the actual CB, and factors in things like cabin area above the deckline (which helps the boat roll back over, and adds extra buoyancy when heeled over more than 60 degrees.
Ross
Jun 15, 2004
14,693
Isn't CB the center of bouyancy?
Aug 21, 2011
8
Venture 22 Aurora, IL
Guess Fedom 77's is the easiest reply. Roughly same as in Mac Manual, but it warns against removing flotation. Blocks that came with mine don't seam to fit and are only about 12 cft. Thats about 800 lbs. Boat displaces 1800 (+ motor & extra stuff). Doesn't it still sink anyway?
Jul 29, 2010
1,392
Jackdaw, Cool diagram on capzising. Too much math for me. I usually hit an Angle of vanishing stability after about the third beer:D. Venture will sink to a certain point and then the built in foam is supposed to keep it afloat although very wet, assuming all the original foam is there. MacGregor actually flooded a boat and it only sank up to the deck. Your V-berth should have flotation blocks and there should be some under the settee seats and in the aft end. If not you might think about adding some. Every time I buy a piece of electronic equipment I stuff the foam packing into the boat wherever I can find unneeded space. Also, Always keep keel locked in down position or you could capsize and the keel will make a very ugly move into the trunk...
Nov 8, 2010
11,386
Most parts of a boat are very close to neutrally buoyant. Just like people! Normally additional flotation just has to offset the weight of the dense keel to make it unsinkable.
But boats don't have to fully capsize to sink. Most go down when they downship water thru the companionway at 90 degrees. Keep your lower board in while sailing! :)
1,392
Jackdaw: ditto that. Have poptop Venture. Never sail with it up. Saw one knocked down and take on lottsa H2O. Didn't self right. When closing poptop always burp corner to get the air out.:snooty: Happy Holidays to all.
