Hi;
As I reported, I believe I have successfully installed RM network that allows communication between:
Axiom 9 MFD
i60 Wind transducer and Control Head
SPX-10 Autopilot
P70 Autopilot control head
GX2000 VHF radio with Camino 108s that provides AIS to radio and Axiom 9
Old Autohelm ST50+ Depth and Speed control heads with their original transducers.
The speed, depth and wind transducers are connected to an ITC 5
The ST50+'s are connected to a D244 junction block and then that is connected to Seatalk to SeatalkNG converter block
Everything has been connected and installed.
The Camino sends out my AIS data (people have seen my boat on their AIS receivers)
The GX200 and the Axiom 9 receive the AIS data and the Axiom 9 shows other AIS boats in my area.
The i60 control head shows wind and direction. It isn't right, but I have not calibrated the instrument or moved the boat at all.
It was put in the water this week and all I did was motor over to my slip.
The wind speed and direction show up on the Axiom 9
I am not sure about the SPX-10 autopilot. The P70 control head shows rudder sensor data, correct heading (well at least it is showing that my boat is pointed 300 degrees north at the moment)
I will mess around with all that when I get on to open water.
My question is about the ST50+ Depth and Speed.
On the ITC-5, the lights are blinking for the Depth and Speed, the light is steady for the WInd.
On the ST50+ gauges, the Speed is showing 0.0, the Depth is blinking 0.0
When I go into the Axiom 9 Network Settings, it will allow me to 'calibrate' the speed by setting ST50+ indicated speed to whatever the GPS on the Axiom 9 shows (I think)
However, the depth option is grayed out and I cannot hit it.
I just don't think the transducers are not working.
Am I missing something? Or is there something I should be looking for?
Thanks
Chris
Toole'n Around
Catalina 380 #16
Rochester, NY
Axiom 9 MFD
SPX-10 Autopilot
Thanks
Chris
Toole'n Around
Catalina 380 #16
Rochester, NY
