So a while back my instruments would occasionally not switch on - once the boat seemed to be warmed up they would so I put it down to corrosion and figured I would fault find at a later date.
I recently installed a new depth sounder for my garmin and as a result removed the old raymarine transducer and ran the new cable all the way through to the helm.
When I was there I decided to remove the Depth and Speed ST50 displays because I have GPS speed and new depth straight to the garmin so they were no longer needed.
When I was working I found by chance that the connection that was power into the depth was the culprit for my instruments (several disconnects / reconnects tracing the beep coming on) as it was daisy chained through.
I removed the depth and speed instruments and wired the power to the remaining instruments (wind and auto pilot) - nothing came on at all. I tried them individually - nothing.
I checked the cable and have 12v. I plugged the 12v back into speed - nothing, tried depth - nothing.
Is there something I am missing that is the reason nothing would be coming on?
I am totally lost, if there is power I expected the displays to light up - there is definitely power.
