ST30 speed problem
kb5rex
Jun 25, 2004
15
Hunter 310 Cedar Mills Marina, Texas
I have a 1998 H310 with a ST30 speed indicator that is reading 0.0. I have removed the transducer for cleaning and turning the paddle wheel still results in a 0.0 reading. Assuming the transducer is bad, I need to confirm that a thru-hull transducer, Raymarine Model E26031, that I have found online would be a replacement for the ST30. Some of the descriptions I have seen say it works with the ST30 or ST60 and compatible with the ST70 and ST290 but I am not 100% convinced it will fit the existing thru-hull. I have scoured the forum archives here but didn't really find what I was looking for. Anyone with a similar experience and could help here would be much appreciated. Thanks.
Jun 6, 2006
6,990
You probably cannot spin it fast enough to get even 0.1 knots to read on the display. Try this: set the display to show the log (NM gone) and then go spin the paddle wheel for a while. If you see ANY increase in log reading the transducer is OK.
kb5rex
Jun 25, 2004
15
Thanks, Bill, I'll give it a shot next time I get to the boat.
kb5rex
Jun 25, 2004
15
FYI update, I replaced my old ST30 speed transducer with the Raymarine Model E26031 and it fit and worked perfectly. Now, my boat is back to 100% for the moment :)
