ST 50 windvane wanted.
Patrick
I have an ST50 windvane that shows the wind speed and direction and is masthead mounted, that was almost taken off the mast during the last hurricane,and now doesnt work. I'm looking for a used replacement.
Trevor - SailboatOwners.com
ST60 should work also
Hi Patrick - You might consider posting a free WANT AD in the Gear Here classifieds section (see tab on homepage). If you find a ST60, it should work with your ST50 setup as well. Best of luck, Trevor
Patrick
Thanks.....
Thanks, I just placed the ad with Gear Here. Note that the ST60 is not compatable says the manufacturer
