I have a 1991 Catalina 30 Mk II. The ST 50 wind & close haul vmg does not work. One reason is because there is no transducer on top of mast, but I don't know if that is the only problem.
Where can I find a transducer for this instrument and any other info. It was made by Autohelm. How do you attach the transduce to the mast? Where does the original wiring run from bottom of mast?
Any info will be greatly appreciated. Thanks, Al Cox
