Michael Bourassa
I have cleaned the wheel on my knot meter while cleaning my boat bottom with SCUBA gear. After this I had to add the max adjustment during the calabration routine to get close to the correct knot reading on the GPS. Does this mean the wheel is still not clean enough?If I remove the hull plug with the wheel in it, what do I use to clean it? Someone has suggested a water/bleach solution. Or would it be better to replace the wheel...how long do they last?Also for the ST-50 wind meter...when you do the two complete circle before calibration, does this automaticaly calibrate the wind machine? Mine was off several degrees before doing the circles and after when I went into the cal routine the windex and the meter seem to match without any added correction.
