SSB Antennas
The traditional guidelines for a Backstay Antenna are to have the bottom insulator 7' off the deck, and 3' down from the masthead. Insulated sections of backstays longer than 35' are not necessary, however a longer antenna may perform better. The RF output from the tuner can be as high as 5000 volts at very low current, and grabbing the uninsulated part of an antenna while the radio is transmitting, can cause a serious RF burn - or could even be lethal! Therefore the bottom insulator is usually put 7' off the deck for safety reasons.If the bottom insulator is to be mounted at deck level, the backstay must be insulated from possible contact with crew, by putting an insulating material over the backstay, turnbuckle, etc. The best material is teflon tubing which has very good insulating properties, however the tubing must be installed on the backstay when the backstay is being fabricated by your rigger. A distant second best material is white nylon "snap on" shroud cover products available in chandleries. Attention must be paid to items such as bonding system wires, that may be attached to the backstay chainplate(s). Also note that a bottom insulator will have to be installed above a hydraulic adjuster (if fitted).Wavelength (in Feet) = 936 / frequency in MHzorwavelength (in meters) = 300 / frequency in MHzAlthough Automatic Tuners do a great job of adjusting fixed antenna lengths to varying frequencies, most antennas are designed for 1/4 or 1/2 wavelength, at some preferred frequency.Insulating a backstay can be expensive depending on what type of rigging you have, wire rope, rod or as on some race boats spectra, kevlar or technora. The cost of installing insulators sometimes leads people to use a standing whip antenna instead. The whip is tried and true and will do the job you require There are whip antennas specifically made for SSB use (23' or longer).Marine SSB Single Sideband Simplified ~ by Gordon WestGoto: http://www.icomamerica.com/marine/ssb_book.aspChapter 9 - Antennas:“... On a split backstay, where the split is below the masthead, use three (3) insulators. The to & bottom insulators are installed on the side of the backstay to be used as an antenna. The other insulator should be paced near the top of the split leg, as close to the Y as possible. This effectively takes the split out of the antenna system. Run the GTO15 up the stay, to a point above the lower insulator (about eye level) ...”SGC HF User's Guide:http://www.sgcworld.com/ftp/Books/hfguide.pdf
