SS Rail weld or cup
Rich
Hello, My rear rail broke at the weld where it mounts to the deck. I was wondering if anyone knows if thier is a cup fitting that will match the angle of the rail or should I have it welded back. I am worried if I weld it back that it might snap agian. Any help or suggestions will be great. Thank You, Rich
Aug 31, 2007
296
Catalina 30 Petoskey, Mich.
Weld it
I would say it should be welded, the first one must have been bad, or it takes alot of stress, if so, welding would be better. The next welder can lay it on heavier. You will probably have to remove the whole rail but oh well. You may want to check the rest of the welds too, this broken one could have transfered stress to the others. Good luck, Dean
