L
Lee
I was prepared to replace the flax in my 1997 Hunter 310 when I realized that the stuffing box nut could not be backed off enough to come off the threads. It was hitting the rib on the bottom of the hull which diverts drip water away from the engine compartment. Unless I'm missing something basic, I assume that the suffing box cannot be restuffed in the water. The only other obvious method is to remove the shaft. I could loosten the bolts from the flange and separate the shaft from the transmission, but I doubt that I could bent the shaft enough to clear the obstruction and If I could, would this be wise to do in the water? Anyone with similar experience or suggestions? I can easily tighten the nut and reduce drip but I thought it was time to replace with teflon. Thanks. Lee
