Assuming its an above deck wheel pilot, are you sure it's the belt squeaking not the drive shaft? A toothed belt shouldn't squeak. Try a squirt of spray lube (like white lithium grease, not WD40) where the drive shaft comes out of the motor. That will work on the lever too. You can put belt dressing from an auto parts store on the belt, but I don't think that's the problem.
