Squealing shaft?
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
So we are motoring along, about to enter the channel into the marina, and a horrendous squealing sound starts down below, echoing throughout the boat. Running down below, I find that the sound seems to be coming from the shaft. I came back up and took it out of gear, out it back in gear, and no problem.
What do I make of this? What’s the likely issue?
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
Could it be the cutlass bearing?
A belt would still be moving unless the engine was turned off.
Dec 29, 2008
806
This is what I am suspecting. It has chirped a few times, then squealed a long time, until
I changed rpms or took it out of gear. Most definitely is not a belt.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I find it hard to believe a cutless bearing would squeal, being immersed in water, and all. I can imagine a transmission bearing squealing, especially if it's "spun," and this can be intermittent.
Jul 7, 2004
8,497
Yeah. I've not had a cutlass bearing go bad but I'd guess the sound would be drowned out.
I would be careful not to cause further damage.
Aug 2, 2005
1,155
+1 for the possibility RoyS suggested.
We found that "dry out" of our old and worn non-vented dripless occurred sometimes when we encountered a following sea. Note: The mating surfaces were very hot to the touch, but "burping the shaft seal" ended the noise. Could a similar noise occur from a shaft packing that was too tight? (We never had one of those.) At the next haul out we changed to the style that had the air vent tube and I do not remember the noise recurring. Ah, but memory fades....that was in 2013 or thereabouts!
Likes: NotCook
