Bob England
Today was spring launching day at my yacht club. Great to see the boat in the water again! So far, I've had two "adventures" -- the rudder split open over the winter, down the leading edge, and when we tried to grind the crack to fix it, the entire fiberglass skin fell off. This required reglassing the entire rudder, and in a big hurry. Also expensive. We just barely got it done before launch. Today, at launch, one of the amateur crane assistants (my club is a self-help club) allowed one of the big shackles that attach the crane straps to get caught under my toe rail. This was on the side away from the crane operator, and before he responded to all the shouting, the crane had lifted the front of the boat partially out of the cradle, by the tow rail! This is on a 10,000 lb boat with an outward turning flange and aluminum toe rail for the hull to deck joint. Total damage was a 1/2" crescent shaped "ding" in the bottom edge of the toe rail, and some minor stress cracks in the glass under the rail. This is a testimony to the strength of Hunter construction. Too bad they didn't make better rudders.
