spreaders
steve
One of my spreaders cracked at the base of the bracket. i'm thinking that i can trim it off. remove the other side trim it to the same length (loss of about 1 3/4 inch) retune my cables and i'm good to go. I hope to replace with original length but i also want to use boat for father's day picnic. anyone have any ideas? thanks, steve mac26x "heard the call"
Dan McGuire
Spreader Repair
I have a McGregor Venture 23. The spreaders are fairly long so the shroud turns in sharply. I once owned a Gulf Coast 21 and the spreader was much shorter. The shrouds were almost straight. My guess is that it will not make much difference, however the shrouds should turn inward. One minor point, can you shorten the shrouds enough for the modification? Dan McGuire
