Spreaders and spreader tips
Philippe
Hello. I have just bought my Oday 192 and have discovered that the spreaders have been bent. Not sure if it happened before or after I bought it. Can they be straitened or should they be replaced? If I need to replace them, where can I find new spreaders and tips? Thanks
Justin - O'day Owners' Web
Replace them
p - While it might be possible to straighten the spreader I think the risk of failure outweighs the cost savings. The loads on the spreaders are substantial and if they are bent they will tend to fail much more easily. I would take the spreaders to your local marine supplier - they may be able to give you similar material you could cut to length and groove to hold the shrouds. If not I would contact Rudy Nickerson at the link below. Justin - o'day owners' web
