Spreader Problem
F
Frank Pain
Greetings all! During my preseason inspection of my H19, I discovered the starboard spreader has developed a 1/4 crack and the spreader is bent down at a 25ish degree down angle. Has anyone experienced this situation? I presume there's too much tenion on the upper shroud causing the problem? Any suggestions on a quick fix on this? Also, what is the cost of a new pair of spreaders? I plan on contacting ZSpar , to see what it will run. Any comments would be gratly appreciated! Fair Winds and following sea... S/V Sea Sun Frank
Dave Condon
spreader
Do not try to fix spreader. Buy new one. Call tom at 904-462-3760 Crazy Dave
F
Frank Pain
Thank You Crazy Dave
Thanks for the input. I'll be caling Tom soon. With your help, I'll be sail'n in no time. Fair winds and following sea to ya! Sea Sun H19 Frank
