I have recently purchased a share in a 1978 Pearson 30. The spreader light does not work. I pulled the switch panel, aft end, starboard side of cabin and found that there was no wire connected to the fuse. No one else seems to know why it was not connected. The problem is that I cannot find a loose wire in that cavity and need to know just how that wire from the mast step may have been routed back to the switch panel area. It may give me a good start in trying to locate it.Any help would be greatly appreciated. I would like to solve this before putting the boat away for winter.Thanks,Dave Seaberg
