We just replaced the original aluminum spreader brackets with the Catalina Direct stainless steel bracket with through bolts. After getting it all back together, we rigged the boat. All the stays tightened up fine, except the forward lowers. Those are incredibly loose. So loose, in fact, that we are resisting sailing until we get them fixed. We tried to buy new (shorter) turnbuckles to take up the slack, but apparently 1/4 inch turnbuckles aren't made any shorter (per both CD and West Marine). After a lengthy conversation, CD recommended removing the forward lowers and measuring them and then they could assess what went wrong. (I suppose moving up the spreader brackets by re-drilling at least one hole is an option, but I'd like to consider other alternatives before getting to that point). We aren't trying to get the boat to racing spec, just to be able to sail it. Has anyone experienced anything similar? Is there a way to safely shorten the shrouds? Or, is there something else we could use (equivalent to a turnbuckle) that would take up the slack? (An couple of additional data points. At the end of last season the shrouds would get loose, but we could still tighten them sufficiently to sail, so the only change has been the new spreader brackets. And, what is incredibly odd, is that the aft lowers did tighten up ok so, if the spreader brackets are off, it can't be by much. Also, the spreaders are still perpendicular to the mast in the new brackets. We didn't adjust them on the upper shrouds at all).
