Sprayhood attachment?
Oct 30, 2019
114
I have had a replacement sprayhood made and on the old one a piece of shockcord was threaded through the front and appeared to just fit under the lip formed by the coachroof and the two pieces of wood on either side. I have done it the same way but it is not very secure - in fact a good tugg on the sprayhood and it pops off. Anyone found a modification that makes it more secure?
John
Oct 30, 2019
1,459
Hi John,
Mine was attached the same way, and on a couple of occasions when I got thrown on the spray hood the whole thing collapsed. I replaced the frame with 7/8" stainless tubing and added a strut on either side from the rear frame to the cockpit combing, ahead of the winch. I also added hand holds across the rear frame. Solid as a rock, and still just bungy'd down in the front.
Peter
www.sintacha.com
Oct 30, 2019
234
Hi Peter
Where did you get this made as I need a new hood for my Series 3. I live in Largs – Scotland for those that do not know the UK.
David Wisdish
Ponteneur V3283
Sent: Monday, May 07, 2012 4:30 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Re: Sprayhood attachment?
Hi John,
Mine was attached the same way, and on a couple of occasions when I got thrown on the spray hood the whole thing collapsed. I replaced the frame with 7/8" stainless tubing and added a strut on either side from the rear frame to the cockpit combing, ahead of the winch. I also added hand holds across the rear frame. Solid as a rock, and still just bungy\'d down in the front.
Peter
www.sintacha.com
Oct 30, 2019
1,459
Hi David,
Steve Birch knows of a person in the UK who makes a very good Vega spray hood. I saw one on a boat ("Shiva") and it was a nice piece of work.
I had a go at it myself. I like the look of the original spray hood so decided to try and duplicate the original frames, using the old ones as a pattern. I bent the frames up using a home-made wooden jig described in Don Casey's "Canvas Work and Sail Repair".
Some pictures at
Being a little nervous attacking an expensive piece of stainless right away, a practice set of frames from EMT (electrical metal tubing) was made first and test-fit on the boat.
7/8" stainless was used for the final set, instead of the usual 1", as it's easier to work with and, I think, strong enough for most conditions.
New mounting plates were made for either side of the cabin that have 2 pivot points instead of 1. This gives a bit more room for the end fittings when the top gets folded down.
Hope this helps!
Peter
www.sintacha.com
Oct 30, 2019
1,459
Almost looks like you know what you?re doing.
Very nice!
Nicholas H. Walsh P.A.
120 Exchange Street
P.O. Box 7206
Portland ME 04112
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain material that is confidential
or privileged. If you suspect you were not the intended recipient, please
delete the email and give us a call.
Feb 13, 2010
528
Sorry about the bottom post on the last one. I use Linux and most lists
there insist on bottom posting. As a result I forget and usually wind up
wrong here and elsewhere as well:) . Doug
Oct 30, 2019
234
Peter
Thanks for the detail that helps a great deal. You have encouraged me to have a go myself.
Regards
David
Ponteneur V3283
Sent: Tuesday, May 08, 2012 6:08 PM
Subject: Re: [AlbinVega] Re: Sprayhood attachment?
